If it could be possible, with which celebrity would you do "petting"?
14
Hi from Wagga
Engine oil dipstick reading
Landcruiser 13B Engine Swap
Hi I’m not shore how you went with this project but on a whim how did you go and do you still have the old 13b engine as I have this car and the engine failed looking for options cheers -
hi I have a 1992 RN105 22R with a G52 box, can i use an automatic gearbox from a donor vehicle (1991 4runner 3vze) and make it work in my manual ?
