[VIC] Sun 20th JAN ***THIS SUNDAY!!!*** :: Mt Baw Baw Cruise
14
Hi from Wagga
Engine oil dipstick reading
Landcruiser 13B Engine Swap
Hi I’m not shore how you went with this project but on a whim how did you go and do you still have the old 13b engine as I have this car and the engine failed looking for options cheers
