Help with 6 cd mp3 head unit
vvtl-i
I recently installed a 6cd mp3 head unit (the one with bluetooth) in my 01 Celica.
The thing is it didn't come with a manual, so I have a few questions.
- When in random mode how do I go to the next track randomly?
The next track button just goes to the next sequential track, you have to wait for it to finish
the current song before it goes randomly to another track.
- Can I play songs randomly from all 6 discs? Or is it only one disc at a time?
- When showing the TEXT (ie track title) is there anyway to scroll the text when there are too many characters
to fit on screen?
- How do I transfer my phone contacts to the head unit? Option to transfer on my phone is disabled.
- Does anyone have a pdf copy of the instruction manual?
Thanks a lot.
You've pretty much already answered your question. It won't let you manually select the next random track.
Knowing Fujitsu 10, probably not.
to fit on screen?
As one of the replies stated above, hold down the text button. However, depending on what type of info you're viewing, it will only display a maximum of 2 lines of characters. SO if you have a really long song title, it ain't gonna display it. If Fujitsu 10 and Toyota had ½ a brain, the whole display would be dot matrix and be able to show artist, album and song title all at the same time.
You can't.
I'll see if I can copy one for you today...
It's a bit disappointing that you can't skip to the next random track, oh well.
Another question.
I've managed to add a contact to the 'Phonebook' but I can't seem to call the contact from the headunit.
I press 'Off hook'
Press '1' and the contacts number comes up
Press 'Off hook' again, but it says 'Outgoing Err'
Am I doing the correct procedure?
Thanks again, manuals are very handy :(
Is anyone getting the same error?
Whenever I try and call someone through the head unit, it displays 'Outgoing Err' in the head unit display.
I can still call through the head unit by dialing the number from the phone.
My phone is the Sony Ericsson Z800i.
Thanks.
press the random button twice to go to the next random song?
so as in, you turn it off, then turn it onto random again
thats how it works in the old 6 stacker
question: how do you edit the name of contacts after you have entered their number?
Edited by bonbon-2zzge
You can set speed dials up instead of looking through the phone book.
I might add that i have a bluetooth 6 stacker in my corolla and after 9months the unit has had to be replaced under warranty due to it not reading disks properly.
Hope you got it for a cheap price
  • 5 weeks later...
  • 1 year later...
Just installed the same model....im having the cd player problems but hey for $250 im not too concerned....the aux and bluetooth make up for it...apparently the not reading CD's is a very widespread problem in this unit
