Toyota TRD Aurion 3500SL
SecaBoy
  • Replies 258
  • Created
  • Last Reply
Top Posters In This Topic
dont think it'll fit... +45 offset and also a different stud pattern i think...
fords are 5x114.3 same as toyotas.. offset is +36 lol
which means that they would stick out an extra 9mm from standard... no?
might get away with it, but it might also rub on the guards... :(
other way man, they would be 9mm further in... if the widths were the same
Pretty sure +36 would stick out 9mm then +45 (same width rim).
yes +36 would sit out 9mm further than +45... but the ford has +36 offset from factory, so putting ash's +45 buddyclubs on would mean they would sit in by 9mm (same width)
You're thinking of it the wrong way. The Ford stocks are +36mm. The TRD is +46.5mm (but in this case lets say +45mm because of the Buddy Clubs).
Put the +45mm offset TRD wheels on the Ford, they will sit 9mm in. Put the +36mm offset Ford wheels on the TRD and it will sit 9mm out.
ahhh yes, you're right... :)
i just realised that when i was thinking about it, i used the +45 as the "original" rim, and the +36 as the "new" rim... :lol: my bad!
anyway, they're going with the car unless daryl wants them.. :D
