College Basketball halftime show got Rick Rolled
- transmission stutter
(and 1 more)
Tagged with:
I immediately thought of sound deadener material which is available from JayCar as a potential solution. https://www.jaycar.com.au/combination-butyl-foam-super-sound-deadener/p/AX3689 -
Hi all, For some reason my 2012 Prado is having dramas starting first time every so often. Regularly serviced 192k KMs. Sounds really rough during initial failed attempt to start. Then on second attempt will start fine no drama's. Sometimes I can hear a little bit of that initial struggle during a cold start and will still start. Everything else seems to be running fine. Thinking it could be a fob or immobiliser issue? Have had the same result with both main and spare key fob. Booked mechanic in a couple of weeks for diagnosis but hoping to point him in the right direction. First video is the no start and the second is immediately after appearing fine. Cheers! cold start fail.mp4 success.mp4 -
1kzte throttle body
5
5
8
PZQ60-00525 Issue
Hey mate! Hoping you’re still here. How’d you go with this? Currently trying to diag the exact same thing in my rzn169r 4x4 2.7l hilux. Smell is getting pretty unbearable but all fuel lines are dry and nothing obviously wrong with any vents or connections (on the surface at least). No smell when idling. Mostly just while driving, especially after a long stretch at high speed or uphill. Noticeable inside, most strongest in the rear right passenger seat - right near the fuel door.
