HID Aiming
Im new to the HID kit thingy.
I need help.. how do i aim my light and how low do i aim >?
you shouldn't have to adjust anything as fitting HID's is only changing the globe....the reflector level stays the same.
What i did was park the car near a wall..n then just aim the light a lil lower..
just low enough that it isnt really glaring for the on coming traffic..
but not too low until u cant really c..lols
i aimed mine a lil lower n till now..i havent been flashed :)
Yeah at first i was really freaked out and aimed them so low that i couldn't see much ahead. If you've ever traveled on that long winding road @ olympic park it can have a good indication as to how far ahead you can see as there is no street lights on that road. But anyhow, park your car perpendicular to a wall (If you're around the Auburn area, i suggest the Reading Cinema carpark) as it's dim enough to see your car's cutoff. The walls also have the concrete filling lines which you could use as a indication and help you level your LHS and RHS headlights. goodluck! =P
Regards,
Kenneth
      help with clutch
    5. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
    8. 2
    9. 1
