Removing Seats
CME-LFT
Hi guys, i tried searching for this, but only found info on modify the rails in the case of putting in racing seats.
That is not my question.lol
I just wanted to know, if i want to remove both my front seats out of my corolla sportivo for various reasons ( easier to put my system in)
can i just undo the bolts that go through the rails,into the floor of the car.
Are those bolts screwed into a Pre-threated hole in the base of the floor or is there a nut underneath that holds it all together that i would need to reattach from under the car when putting the seats back in?
Hope its not too stupid a question :blink: Thanks anyway
      Typical Price for a Replacement Key - 2000 Toyota Torago
    2. 1
      Invisible Instruments fix
    3. 0
      Finally found all Tarago's 6 speakers - 2 in roof lining
    4. 0
      Can I use USB hub to get more USP ports?
    5. 1
      Replace Front RH park light Corolla 2006
    6. 1
      Rav4 smart key keyless entry
    7. 0
      What do I need to change for a 2.5in lift n70
    8. 1
      2005 Toyota Camry Altise - changing transmission fluid?
    9. 13
      Starter motor issues
