Leather care
Blackkluger
http://au.toyotaownersclub.com/forums/inde...l=leather+seats
last week i bought the armor all leather wipes/conditioner. I used it to clean both the kluger and the stivo's seats. it was quite good although if your seats are very dry like ours were they dried out very fast. I ended up using 1 wipe per seat before it was completely dry mind you there were only 20 wipes in the pack. It's amazing how much dirt is on a seat even though they look clean. Anyways it left the seats very soft and slippery and didn't leave any yukky residue and didn't clog the pores in the stivo's seats. i would rate this product 8/10 !! :D
I have never had leather before, so anyone here know what you need to do to keep the leather in tip top shape?
does anyone know ow often i should clean??? I have only had the car a month, the leather still looks good but i want to take all the preventative steps to keep it tip top
Thanks in advance
I'm trying the armorall wipes as well. Available off shelf in Coles. Seem to work a treat. The wipes are handy in the glovebox.
does anyone know how often i should clean??? I have only had the car a month, the leather still looks good but i want to take all the preventative steps to keep it tip top
Thanks in advance
I just finished treating mine, and the leather was bloody thirsty! I'd say they would all be pretty dry from the factory, so if I were you I'd treat mine soon, and then every say 8 weeks after that? Seats came up beautifully with the Meguiar's Rich leather conditioner, but any non-greasy leather conditioner should do the trick B)
Thanks in advance
OFF TO SUPACHEAP I GO......
Thanks in advance
sorry for shouting....cheers holmesie
Be aware of those wipes, i personally would check if they are moist as our local one have some marked down, so i thought id check if they were moist, they were dry as a bone. I assume a bit of water would fix it but didnt take the risk.
Thanks in advance
Meguiars Gold Class Leather Conditioner....is Gold!!!...looks great, you were right holmesie the seats are v' thirsty.
Good to hear mate - that initial treatment will be the hardest work. When you re-treat them next time it should be a lot quicker and easier :clap:
      Code P004B
      Upgrade from 2012 to 2023
    6. 3
      Towbars
    7. 5
      ASV50 Camry Head Unit Options
    9. 2
