Adding a sub to my stereo
Hey people...
I have a 2004 camry sportivo and want to add a subwoofer to my stereo, i have the amp, and i have the sub... but when i went into alberts they asked me all these questions about the back of my head unit... like does it have rca out-puts and other questions that i kinda had no idea of... does anyone know if the stock head unit is capable of attaching an amp and sub to it, and if so is there anything i need to know before i go to someone and get it installed??
Thanks Heaps!!
Hey people...
Thanks Heaps!!
No, the standard head-unit does not have RCA outputs. You can purchase a LOC (line-out converter) to connect an amp to it. I would however, recommend buying a new head-unit.
Moving to Audio.
yeah new head unit for sure. If its not a normal din size, u might wanna use the stock unit with line out converters. my mates mazda does that and still sounds as good as some after market head units
  • 10 months later...
As mentioned above, no there is no RCA output as expected from stock head units.
And mentioned as well you can get a line out converter.
I have gone this way myself, and it ain't bad.
Converted front speaker wires to LineOutConverter to a 4 channel Amp.
Bridged the rear channels to the sub
and front channels to the front speakers.
I chose to convert the front speaker wires to the LOC so I can later Amp the front speakers for sounds quality.
However you can choose to use your rear speaker wires to LOC if you want.
All in all, the best solution if you want to keep a stealth, non-modded look and you want to make use of your radio/cdplayer and your steering controls.
BTW, I have a camry sportivo which is the reason why I have gone this way. The standard speakers in the car can handle a little bit of extra power.
But that is probably because the sportivo speakers are upgraded from the standard...say altise range.
But as mentioned, the best way to go is to get a new deck. Way better sound quality if you are picky!
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
    5. 8
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
    9. 12
