Remove the grill
Hi all, just got a chrome grill, but i don't know how to remove it....i pulled out 4 clip and 2 screw...but the grill still couldn't be removed....If someone could help me...
Mate make sure you remove all the screws as per this thread
http://au.toyotaownersclub.com/forums/inde...showtopic=16985
Then you may need to use some force (the one in there is pretty durable), it will come out though, replace the new one, same way you took the old one out. (just without the force)
and hey presto.
Look forward to seeing some pics. Also is it the same as Bondies and where did you get it. I'm quite keen to get one
Cheers
and hey presto.
thank you so much...I got the new grill fitted in... Later I will post some new pic.
