My every day driver with some mods.
Under the seat mods.
Engine - V6 VP Commodore with 4lb blower fitted (aftermarket)
Injection - 50/50 water/Metho (cold air induction)
Gearbox - 4SP VP Commodore
Diff - original Toyota rolled to suite
Wheels Front California 8x15 - 205x65x15 Bridgestone
Wheels Rear California - 10x15 - 265x70x15 Hankook
Exhaust - dual 2" from cat to twin stacks behind cab
Brakes - Hi-lux Front disc, Rear original truck drums
Suspension - Front reset coils lowered 4"
Rear original 2 ton leaf springs lowered 7"
Interior (not finished) full set Pro-Comp Gauges,carpet,sunroof
This is used as my normal daily car
And it's all legal I have the engineering certificate.
best part about it being classed as a truck is a lot of car regulations don't apply.
Nice Conversion Mate ! That thing must fly - although scary around the corners!
What did you actually run down the Qtr Mile ?
Cornering. in the dry she's not to bad, the suspension is so tight. in the wet is a different thing she just wants to slide everywhere.
Down the 1/4. not the best there best run was 16.9 @ 125.4kl's. biggest problem was trying to get the rear wheels to grip, all they wanted to do was spin most of the way down.
Main thing is I have fun in it.
Just strap four of your best mates over the rear axle so that...
A: They share the fun with you
B: More Traction ! :lol:
Must pull alot of looks too. Nice one man.
B: More Traction !
LOL. :lol: Thanks.
A: true untill it rains.
B: unless they weigh 1 ton or more not much to gain,she'll do this with a ton on the back over the axle.
not wrong there, it turns heads every where & gets comments.
when I first started it, it was only to give the old girl a bit more power. then I thought ok it gets along pretty good why not give her a bit of a face lift to.
then after a lot of pressure I entered it in the 2004 Liverpool Nationals, and got 2nd place in the 'Top Ute/Pick Ups' section.
so Thanks again.
  • 8 months later...
thats neat!!! semi slicks might do the drick 4 grip or some weights!
      Tyre Sale Specials
    2. 0
      overheated engine
    3. 1
    4. 62
    5. 1
    6. 1
    7. 1
      Tyre Sale Specials
    8. 10
      Android auto
    10. 0
      Remote start
