1994 Hiace Electrical Problem
muzerb
The following lights quit working:
Meters Illumination
Tail Lights
Plate Lights
Fog Lights
All fuses checked out ok and I also swapped identical relays, no luck.
Dealer is way to far from where I live and does not want to share the electrical diagram.
I was trying to find the diagram and or repair manual, but can't find one for 1994 models.
The closest thing I found is at
http://www.autoepc4you.com/catalog/view/?id=582
However, I am not sure it is the right one.
That manual covers models LH and RZH
My model is Y-KZH106G-JRPET
Is anyone aware of the main differences between the LH RZH and KZH models?
Any suggestions on where to get a diagram and/or manual?
Thank you very much.
Sorry, I forgot to update this post when I solved this a while back.
You are right, it was a fuse.
I found and additional fuse box hidden behind a panel on the passenger side that was not documented in the Owners Manual that I received from JPNZ International.
Edited by muzerb
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
