JDM COROLLA 2ZZGE SLEEPER
matt_glad
Head goodies have arrived the valves are stronger stainless steel and coated in Nitride they also flow 2cfm more than factory. Springs allow 9000+ rpm due to higher seat pressure.
Supertech valves
Supertech springs and Titanium retainers
ARP head bolts
Very nice. Where did you get the supertech valve springs and seats from? And how much?
Imported them for about $400 for valves and $500 for valve springs and titanium retainers including shipping
PM Me and I will pass your details onto my supplier :)
Edited by matt_glad
Cars making good progress, dropped it off to Alex at Highbrook Automotive (New Zealand)
Pulled gearbox out, found standard clutch was slipping its ***** off after 30,000 km. Clutch got sent to autoclutch to be upgraded and new organic disk, since its my daily drive.
2075LB clutch
Alex and myself cracking open the gearbox
Edited by matt_glad
interesting build up, good luck with it!
Thanks, I have been driving around for the last week with new bearings, clutch and LSD
Great news is I now don't have a gearbox whine on de-acceleration
The clutch has a bit of shudder if you try and slip it more on/off now
The LSD did need some modification for speedo ring but no biggie
The best news is I no longer wheel spin on take-off great to have some traction
If i drop the clutch it leaves two nice black lines :)
Edited by matt_glad
  • 6 months later...
I have finally found a spare engine to rebuild got so many goodies to bolt in will take pictures of my progress if anyone's interested. So far the engine has been stripped down.
Plans are.....
Heat coat ported headers.
Powder coat rocker cover gloss black to match injen intake - Done
Modify runners to remove factory cast marks - Done
Modify plenum to remove factory machining marks around the throttle body and remove internal restrictions. - Done
Powder coat intake manifold silver - Done
Port and polish head
Fit supertech valves, springs, ti retainers.
De bur the engine
New factory pistons
Lightweight crower rods
New bearings
ARP bolts
Circuitworx oil pump
With the rest of my current bolt ons
Edited by matt_glad
  • 4 months later...
  • 3 months later...
  • 4 months later...
