2005 V6 Sportivo
Lambu
36 psi (250 kpa) front and back is what I used to run on my gen5 Sportivo.
The tyre placard will only give you the minimum recommended tyre pressures.
Edited by SupaTouring
at the moment i've got the standard rims with 205/60-16's on it and am running 36psi on the front and 34 psi on the rear and drive alone 95% of the time,. i find it works very well and have had the same tyres since i bought the car in nov 07 and they still have HEAPS of tread
but good wheel alignment helps too
Edited by lateralus
yeah, i've also ran 36psi as well.
depends though, sometimes i feel that 36 is a little too pumped and it feels like that the tyre contact could sometimes be a little less.
But I'd still think 34-36psi.
Am also on the stock Michelin Vivacy tires with 38psi at the front, 35psi at the back; drive alone about 98% of the time; 99% of time in city traffic.
Have tried 36psi at the front and found that steering feels inaccurate as there is more flex in the sidewalls, but is offset by a slightly more comfortable ride especially going over bumps.
36psi sounds better for the 4-cyl model as the engine is lighter.
-m_luke
