93 Camry buying tips?
Power
Hi everyone
Im about to buy another car, and I have decided on a Camry :)
My friend is selling a 1993 Camry, not sure exactly what model, but I was just wondering if there is anything in particular I should look for when I check it out in a few days.
Any help would be appreciated.
Cheers
Checks for oil leaks, especially from the main seals, no doubt there will be a bit of seepage, but just make sure it’s not too much more than that.
Normally the worst thing that can happen for these engines are the main seals in the engine... then you'll have the engine mounts go. I've had to replace engine mounts in my 94 4 banger and my 95 V6 within the last couple of years (a V6 mount was only replaced yesterday).
Other than that, maybe the ceiling lining and door trim will start to peel off... not much else really. Just like any car, if they've been serviced when they're meant to be, there's no reason why you'd have a problem mate.
      3rd Gen (XU50) Kluger new aftermarket radio install
    2. 0
      Front Cameras
    3. 51
      Flashing 4WD Lo and VSC and Engine warning lights
    4. 51
    5. 1
      1kzte throttle body
    6. 0
      Aftermarket parking sensor
    7. 0
      Long start time when engine warm - 2004 Corolla
    8. 4
      Head Unit with Apple CarPlay
    9. 8
      Brand new Prado 2022 with intermittent engine/transmission stutter
    10. 1
      Corolla 2007/2008 ZRE152 2ZR-FE Hood insulator
