Lowering the Stivo
hi all - im just in the process of attempting the king spring low front and the super low back configuration and was wondering if
changing to 18 inch rims later on will affect the car now that is lowered.
Going on king lows at the front and king super lows at the back on 18's might create some scrubbing issues or bottoming out when the car is loaded but i'm not too sure, i never tried it. You might be ok because you won't be sitting as low as my car.
I just went from stock suspension straight to cusco zero2 coilovers. Take a look at my post here
Kenji
      help with clutch
    2. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
