Hi all
I'm hoping someone might be able to help me with a Toyota Corolla 2004 model not starting. I left the lights on during the day so this fattened the battery. First started by push starting but would not fire. Them jump starting would turn the engine easily but no firing so it is as if the ignition is off. There are not light on the dash when key is on. Fob won't lock the doors so I suspect the immobalizer is stopping the ignition and the fob won't turn it off.
Took battery out and charged all day then tried again with the same results. Could it be the fob? The red light on the botton works. Is there a process that turns the immobalizer off to get ignition? I'm stuck. Any help will be appreciated.
Jeremy
I assume its the factory immobiliser?
Typically if the battery is reset and the immobiliser kicks in there is a set time to wait before it deactivates. Wait it out for an hour and try again.
Doubt it is the fob.
No luck as yet still no ignition. Turns car over no worries but no dash lights and doesn't fire. Anyone had this problem or know who could fix it. Need help.
if its running the starter then it shouldnt be the ignition cut. maybe fuel pump is dead. can u hear the fuel pump prime and is there fuel in it??? someone may have syphoned ur tank while u were at work...
      Tyre Sale Specials
    2. 0
      overheated engine
    3. 1
    4. 62
    5. 1
    6. 1
    7. 1
      Tyre Sale Specials
    8. 10
      Android auto
    10. 0
      Remote start
