I have a 1987 Hilux surf LN61, I was driving down the road and the charge light came on, the indicators and instrument cluster stopped working, the alternator is not charging, everything else seems to be working ok, all the fuses are ok, dose anyone have any ideas or have had this problem before
Hey!
Cant guarantee its the same problem but the symptoms seem very familiar! Had a 1997 Magna... all the wiring in the alternator had melted, took it to an auto electricians and that repaired/replaced the wiring but commented they repaired it a little better than factory wiring due to the fact i had two amps running!!
Damage was around the $140 mark which i guess wasnt as bad as i imagined.
Hope yours is not so serious also. Good Luck
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
