Hi All,
have an 06 Conquest ZZE122R. battery i assume is stock. it is an FB Hi Dash (not sure what model) looking to upgrade the battery for a nice big deep cycle and wanting to know what fits in the factory location. does anyone know the largest dimension battery i can fit?
Cheers
I fit a big ***** 600cc falcon/commo sized battery in my stivo, required a little modding to the battery bracket but as far as space was concerned it fit fine.
Go to your local battery specialist and check out some Optima/Oddyssey deep cycle batteries...
The Optima D51R could be a good upgrade and of similar size...
yeah +1 optima
...personally, ive got a nissan x-trail battery shoehorned into mine. held in there by cable ties haha
Cheers for your responses guys. i compete in car audio street classes, so modding factory holder is not an option for me unfortunately. i guess i'll just have to disconnect my power cables and take the sucker out to measure it.
thanks again.
Optima YellowTop is the way to go, i got one and its awesome
Whats the difference between going to a larger cca battery compared to getting one of those yellow top deep cycle batteries?
CCA = Cold Cranking Amps, basically how much "oomph" the battery can supply to start the car
Deep Cycle = A battery which can be run to a very low charge and still function correctly, designed to be drawing current for long periods of time.
Most normal car batteries are _not_ deep cycle (deep cycle is common for marine batteries, electric vehicles etc though), they are called SLI (Starting, Lighting, Ignition as that's all they do, start the car and run the lights if the engine is turned off) as once the car is running the alternator provides all the juice. Deep cycle batteries for cars are used when people want to run stereos/subs etc for long periods of time whilst the car is turned off and thus drawing juice from the battery. It also allows the car to be started after the battery has drained for much longer than normal car batteries.
      Tyre Sale Specials
    2. 0
      overheated engine
    3. 1
    4. 62
    5. 1
    6. 1
    7. 1
      Tyre Sale Specials
    8. 10
      Android auto
    10. 0
      Remote start
