PS3 Slim
Styles
Hi All,
Just in the USA atm & i was wondering if anybody knew if the new PS3 Slim from USA would be compatible here in AUS or if the games in the USA will work with the PS3 here in AUS?
I know i would need the adaptor for the power point, since it's a different plug.
Thanks Heaps
Edited by Stylusion
As far as I know, all PS3 game titles are region free.
I have a PS3 from HK and I can play PS3 games from both Australia and Japan. However, I can only play NTSC/J PS2 titles on it.
Is the slim a lot cheaper in the USA?
The biggest difference will be that USA models will run 130V where australian models will run on 220/240V
Whether the transformers in the power supply (On the cable for slim lines i think) are correct is the biggest issue check the sepcs on the tranny and see if it will run 240V down to the voltage required for the unit. I suspect you might need to buy another power supply to run it here.
