I believe I have exhaust gas leaking into engine coolant. I can see wisps of smoke coming out of the coolant reservoir, when I take off the radiator filler cap. The problem started when I overheated the engine, running it 8km without water. :o I need to have someone take off the cylinder head, and get a look at the condition of the bore, to see how much damage is done. Can anyone advise me if the engine will need to be removed for this inspection?
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
