wut size 2002 MRS rim?
waiwong38
hey i want know wut is stock 2002MRS rim is
5x100?5x114.3
15?16?
offset?
i might get MRS soon ;)
want know more about that
cheers
i know fronts are 15's and rears are 16's if that help. Ask SD
5x100?5x114.3
15?16?
offset?
cheers
It'll be 5x100 without looking it up; Toyota never really did a PCD of 114.
Unsure of offset though.
A bit of random information on the MR-S 1zz engine; the head is slightly different to the 1zz put in other Toyotas in that the valves are larger ;)
5x100?5x114.3
15?16?
offset?
cheers
Just about every large Toyota made after the mid 80s has 5x114.3 PCD, including widebody-onwards Camrys etc. Hell, even the new Corolla has 5x114.3. The T-series Celicas and the SV21 Camry are about the only Toyotas with 5x100. And as for 4x114.3, that'd be pre-X8 Cressidas, all RWD Corollas bar the KE1x and KE2x, all RWD Coronas, and most likely some more too.
And I think the ZZW30 MR2 (aka the MR-S) has 4x100 PCD, not 5 stud.
5x100?5x114.3
15?16?
offset?
cheers
SA/RA celicas where 4x114.3 too
    3. 14
      Hi from Wagga
    6. 2
    7. 2
    8. 2
      Engine oil dipstick reading
    10. 1
      Landcruiser 13B Engine Swap
