When I first drive my car out I hear this one knocking sound after my first gear changes and then I won't hear it again
has anyone had a similar issue.
Please reply
Thank you.
It is your ABS self-test. This will apply to you as well:
Are you referring to the sound you get when you take off for the first time after starting your car, and it does not occur afterwards when you get your car rolling?
If so, this is to do with the ABS. Every time you start your engine and then drive off the ABS performs a self-check. The service manual best describes this:
When the vehicle speed first becomes approximately 4 mph (6 km/h) or more after the ignition switch is turned on (IG), each solenoid valve and motor of the brake actuator is sequentially activated to perform an electrical check. During the initial check, the operating sound of solenoid valve and motor can be heard from the engine compartment, but this is not a malfunction.
Thank you your information was very helpful
      Tyre Sale Specials
      overheated engine
    5. 62
      Tyre Sale Specials
    9. 10
