Mirror indicaters for 2005 model (36 Series Camry)
Ronnyboy
Does anyone know where i may possibly be able to get Mirror Indicaters for my 36 Series Camry.
I came across the following pick, not sure if it is aftermarket or genuine, but am pretty certain i havent seen these on NSW Roads....
You can buy genuine Toyota ones
RH Side: 87910-06906
LH Side: 87940-06906
HERE are some shots. I paid $219 for both (full assembly).
These turned out really nice. It kinda sticks out a bit yeah?
Have you painted the prime cover yet?
I will get a few quotes tomorrow..
These are from Aurion and much better than original ones. You just need to wire them up to the side indicator. Also you will need to redrill holes to fit them but well worth it.
if they are from an aurion are they are striaght fit
Ok, i got a quote from Toyota, this is what they quoted me
RH Side: 87910-06906 $64.74
LH Side: 87940-06906 $64.74
Both available in stock.
Ok i dont think this should be that cheap, is there any other parts i require?
Sounds a bit too good. Why not go to the dealer and see in person. You should get whole assembly with the mirror.
    2. 4
      Head Unit with Apple CarPlay
    3. 8
      1kzte throttle body
    8. 3
    9. 5
    10. 5
