Hub Swap
So, as you may know, celica's run a 5x100 PCD hub in them... which is an absolute pain in the ***** to get wheels for
So i had the crazy idea of swapping some hubs/rotors from a Gen III or newer camry (which has 5x114.3 - a VERY common size) on to my car.
I can get the parts cheap as chips, so does anyone see any reason this would not work. (aside from the ID of the hub being diff, etc. I have not done any measuring yet.
I dont trent... but i went to the wreckers with a set of verniers and did some measuring.
Next step is to measure my car
It is looking good thought... they look virtually identical to the hubs on my car.... just hope the measurements are the same
So, measurements
Front;
Bolt Spacing:
Gen 3 Cam: 51.7mm
Gen 5 Celi: 42.4mm
Hub-into-susp width:
Gen 3 Cam: 28.2mm
Gen 5 Celi: 27.85mm
CV shaft size:
Gen 3 Cam: 21.7mm
Gen 5 Celi: 21.53mm
Rear;
Bolt Spacing:
Gen 3 Cam: 70.1mm
Gen 5 Celi: 70.15mm
Gen 3 Cam: 28.2mm
Gen 5 Celi: 28.2mm
Conclusions;
rear hub assembly will basicly bolt right on... easy as pie.
front hub assembly will not bolt on.. meaning either i need camry front suspension... (which will fit) or, just need to get the guts of the hub assy, rotor, etc
decisions decisions....
Mick I have a pair of front hubs from a gen3/4 Camry that I want to be rid of. Also have a pair of rotors (275x28mm) and some Avalon/gen4 Camry single piston calipers that fit them if you are interested.
I could be, how much do you want for them?
When I bought them from the wreckers I paid $70 for them.
Make me an offer.
i was waiting for a regular boostcruising member to offer you:
-an xbox controller, a vn open diff, a birdcage, vl grill, some black steelies, a fish tank and $10 your way
