sjreng
Not ideal where you are but I would ry a couple of things:
Either disconnect the batteries (both) and leave for a good 10 mins - enough time for all
electrics to discharge.. Another one which worked for me was to disconnect the ECU - big
plug on the passenger side firewall. Same thing, allow for electrics/electronics to discharge.
Not practical for you at this stage but if you can get a Scangauge. This will allow you to clear the
codes.
Car has gone in limp mode. I had this problem several times whilst towing a caravan due to
a performance chip which would cause a limp mode. No more as I have had the ECU remapped.
      Centre Bearing Replacement
    3. 6
      maps in 2017 Camry Altise
    6. 5
    7. 4
      Front Cameras
    9. 51
