Loud noise from steering wheel
httttt
The other day a very loud noise came from the steering wheel while reversing out of a drive way.
It sounded like an old metal hinge opening up that badly needed oil. That is the best I can do to describe it, it hasn't happened before or since.
I am not overly concerned at this point because I haven't been able to recreate the sound but I thought it would be good to ask if anywhere else has had the problem?
  • 8 months later...
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
