Going away....
I always heard people talk about un plug-ing the battery... But at the same time, that will reset things like clock etc.
If you aren't too concerned about losing your radio presets, clock etc. - it might be a good idea to disconnect the battery. Nothing worse than coming back to a battery that become so discharged that the acid level is below the plates. Happened twice to me an a few times to friends who have gone overseas for more than a month, and usually results in having to buy a new $160 battery...
You could also see if somebody could stop by once a month or something and hook up a charger or take it for a drive (if you can trust them of course!)?.
    2. 16
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
    6. 8
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
