Greddy Emanage Problem
...quite sure.
I've done more conversion wiring and emanage installs than most...
The emanage is giving him an ignition fault code for only one of the coils, if it was a ground issue with the emanage it would be spitting out more than one code.
With the home-made loom adapater that's being used in this setup, if it's not treated with care it's easy for one of the legs to get a hairline crack in it too which is hard to detect when it's covered in heatshrink.
Edited by rollamods
...quite sure.
I wish you hadn't said that....
I inspedted the wiring to the best of my ability and I still can't find any pulled wires or any disconnections as such. Its also doesn't help when I'm not too sure where I'm supposed to look..
Is there a thread or picture you have on hand that shows where that loom is supposed to sit behind the glove box? Maybe its the way I've stuffed it there thats causing the problem, but I'm not sure...
Would I have to remove the heatshrink to inspect further? What are the consequences if I have to do this?
      ASV50 Camry Head Unit Options
    4. 2
    7. 14
    8. 2
      Hi from Wagga
    10. 2
