Does anyone know where microphone is located and if it is possible to adjust its volume?
Thank you for your reponse.
  • 2 months later...
If you are having problems with your Prius's handsfree microphone not picking up your voice/sounding quiet, try the following:
1. Turn on the car
2. Press the Display button (on top button on lefthand side of MFD). Release button.
3. Press and hold the Info button (second top button on lefthand side of MFD). Keep holding.
4. Turn the headlights on and off. On and Off. On and Off. On and off. (twist the righthand side stalk, flashing the highbeam wont work)
Your MFD should then flick to a maintenance screen, go to the bluetooth tel check/ i think then the bluetooth handset check : then turn up the send volume to 3 or 4. Problem solved.
Resources:
Vid of how to get to maintenance menu. http://video.google.com/videoplay?docid=104914993074462017#
http://www.toyotafans.net/microphone-volume-adjustable-t4450.htm
Definitely works on an Australian Prius Itech 2007 model. People say its a 1000x improvement on handsfree.
  • 4 weeks later...
Thank you very much for your reply.
Unfortunately, my model is 2008 and has a different interface. Will try the google link.
Cheers,
Bozena
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
