Hi all
I opened up the door light cover but could not find the wiring connected to the bulb holder (initially thought the bulb has blown). So the wiring could be inside the door trim but I need guidance on how to remove the door trim.
tried searched 'door trim' but could not find anything on how to remove door trim :(
Any help is much appreciated.
I shall look at the manual on the Engine_hood_door pdf for assistance then
Actually, from what I recall (my laziness is preventing me from loading the manuals), I think the manual you are after is the Interior.pdf
Weird enough ... it is actually on Exterior pdf (EXTERIOR – FRONT DOOR BELT MOULDING) which reference to ED ... which is the Engine_hood_door pdf ...
cheers :)
Well there you go. Guess my my isn't as good as I thought it is. I never used the manual to remove my door trim though :lol:
Edit: That said, I probably recalled seeing a diagram like that on 'IR-14' which pretty much shows you what holds the rear door trim on.
      Tyre Sale Specials
      overheated engine
    4. 62
      Tyre Sale Specials
    8. 10
      Remote start
