Hi I have a corolla 04 model stock with a 1zz-fe engine in it. For the past 8 months i've been having trouble with it starting when it has been driven upto full temperature. It starts fine straight away when you kill then engine but leaving it for about 10 minutes it has difficulty starting. Before when the problem came about I did not know much about the problem. This may become of some help. I would previously crank the engine untill it would start, which would take about 5 - 10 seconds. But what I have done lately is crank it for 2 seconds and then stop. With the ignition in the 'ACC' possion, this would let the fuel pump, pump fuel and build presure. Then it would start no problem. I took off the fuel line going to the engine, and it would pump fuel no probs whilst cranking. Sounds like some ignition problem. These are the things i've tried;
New plugs
Cleaned throttle body
Tried different qualities of fuel, whilsts running the same one for 3 times in a row
Added a fuel additive to clean injectors etc.
Still no success. Also fuel economy is not good either. on a tank only get 400kms to 425km. Before used to get 500 easy. Do not know what to do.
      Android auto
    2. 0
    3. 0
      Remote start
    4. 1
    6. 10
      Android auto
    7. 10
      Android auto
    8. 1
      Turboed Corolla Overbuilt?
    9. 3
    10. 3
