New Alternator
jack_the_lad
Turns out the alternator might have **** it's self as the battery light wont turn off even though I have put a brand new battery in it, I have only had the car 1 month. Does any one know how much a new alternator is or would a second hand option be alright? I'm on the south side of Brisbane if that helps any info would be appreciated.
cheers.
I have just had a test with a century tester:
Battery test results-
marginal
Alternator results:
Suspect
charge volts: 11.62
charge Amps: 0.00
Ripple Volts: 10.8mV
Amps Drain
Pass
I think that means the Alternator is stuffed , I heard I could use the Alter out of a camry?? as they are the same 2.2lt??
I got a Denso alternator from 'Redlands Auto Electrical' on 3286 2272; they are at Cleveland.
I tried to rebuild mine and of the 8 diodes, 2 had burnt out. The bearings were stuffed, but the brushes were still good (there is so much meat for them they'd last 100 years). With all that wrong I just got a new one. Can't remember what I paid exactly, but I remember that mob was the cheapest, and could get it the fastest for me. Don't waste your time on Toyota, they want like $600 (and it's a Denso anyway).
You'll have to take the alternator off to get the part number for them.
Get me the genuine part numbers off the alternator and I will most likely find you one on monday.
The Toyota number will be 27060-***** Denso number should be 101211-****
Also would help if you had the vehicle year, month and engine model.
PM me your e-mail address if you want my mobile number.
Regards
Bris Southside resident too
      Landcruiser 200 GPS
    2. 11
      300 series turbo issues
      Any 2L motors for sale?
      Car Detailing Recommendations
      Proud Owner of Toyota Crown
      Hilux Dash Lights
    9. 1
      2020 Corolla service question
    10. 1
      RATTLING CAMRY 2013
