Hey guys would love to know if anyone else has had a similar problem with a fix.
I have been having an annoying sequel coming from somewhere sounds like its under or behind me
every time i take off or am on the lower end of the 1, 2 and 3rd gear. It usually only stays until my revs are higher.
I had the mechs tighten my drive belt the other day and the problem went a little bit but is back bad again. Its really
frustrating. anyone got any knowledge on this?? any easy fixes?? It sounds like a belt slipping not really like a brake pad or something or it
sounds like something is rubbing or what not. any help would be appreciated. Cheers
it is a manual 4x4 dual cab ute if that helps.
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
