Weird Power Windows Error!!
N3ptuNe
Hi All,
I did a search on the net prior to this and found nothing. I'm sure it's nothing, just a fuse or Battery related.
The problem persisted immediately after I changed Oil, it was dark (pleb garage)so I utilized my high beams for some light aid!
changed the oil started the car, all good, packed up. 2 minutes latter my Car doesn't boot up, obviously battery 'cause it sounds like a silenced MP5 on burst lol! when igniting the ignition.
Anyhow I waited a few hours and gave it a go, she started ASAP! but! power windows don't automatically go up or down, the auto light is flashing on the Power Windows buttons, is this weird or what! has anyone ever experienced this before,
I will go through the fuses in the morning, however the Windows do go up and down manually by pressing the button, just not automatically.
Edited by N3ptuNe
So, I'd suggest winding it down to the lowest point, keep holding the button for about 10 seconds... and do the same for winding it up...
Had a similar function on my bmw, it makes a click after it's held down for long enough to re-establish it's full open mode to full closed mode
    2. 16
      2000 Corolla Ascent - clock.
      ST205 for sale
      Rukus for sale
    6. 8
      CH-R sudden engine failure
      2Door 1975 KE30 Corolla 4Sale
      Hi from Wagga
