Drive Belts
mr_grumble2010
Hey Mr Grumble
According to the Bosch Parts system there are possibly 2 belts
4PK1165 OR 4PK1180
Easiest way is to steal a relative's sewing tape measure, stick one end to the belt and measure around the whole belt(pulleys and all). This should get you close to what you need. Had the same with a Daihatsu Sirion with no markings on the belt
Just don't get caught with the tape measure. lol
P.S. The 3PK means 3 rib the 850 means 850mm total length
:o :o :o :o
My life's not worth that !!!
The last time I "borrowed" something of the missus, I came very near to wearing it.
Where is it written that Tupperware CAN'T be used to degrease in ????????
Anyway, I will see which one is nearest to the length required.
At a guess, I'd say one was with Aircon and the other without.
Cheers....
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
