Seat rails - BRIDE
Hey all,
Just wondering where I'm able to source seat rails (bride or recaro) to fit the driver's side for a ZZE chassis Sportivo? I'm having major difficulties at the moment.
If it matters the seat is a BRIDE CUGA.
Has anyone else done this? I realise theres a set for sale in Vic at the moment, but I don't really need the pair...
Thanks in advance
Alf
Seat mounting width is standard between the high end seats like Bride and Sparco.
Be sure to check out the Bride website to make sure you get the rails you want. Some, like the FIA spec ones, are made to order so there can be a couple weeks wait for it to be made. They do low profile ones, fixed rails; side mount, bottom mount to suit the seat you get.
pretty sure they make a few type of rails too suit both recaro or bride seats.
just need to confirm with the type of seat that you want to get. thats all..
might want to check with dennis_123 he just order some rails from japan
Edited by stock
last month i ordered my rails from www.perfectrun.com.au
just tell them what seats you got and they will tell you the suitable rails
i quoted rhdjapan, nengun, perfectrun etc, roughtly +/- $20 between them.
The Bride rails are holding my Sparco seat fine, I didn't tell them any different size. Just need to make sure the mounting width is 200mm wide from memory; and the obvious issue of side and bottom mount seats.
I replaced all the bolts provided in the Bride kit with grade 8.8 high tensile bolts. There are no markings on the provided bolts, so don't trust them.
cool i will keep that in mine... thanks for the info
Thanks for the replies guys,
I've been spending the past week trying to modify Andy's old rails, no show. Might have to just bite the bullet and get the genuine bride ones.
Thanks in advance
Alf
Can someone confirm the DRIVER'S side number? I've emailed Perfectrun and they've quoted
"If you are after the one for right-hand side drive model, T187RO is the one for driver’s side. T188RO is for left-hand side seat (passenger side in Australia)."
Here you go.:)
http://www.rhdjapan.com/bride-seat-rail-subframe-type-ro-toyota-64218
ZZE...
Left= T187RO
Right= T188RO
Just be sure to check that your seat is suited to this type of rail.
  • 3 months later...
Here you go.:)
ZZE...
Left= T187RO
Right= T188RO
And for ZRE owners...
Left= T183RO
Right= T184RO
:yahoo:
so are these numbers able to hold SR3 seats? or do i have to look for another number?
  • 5 months later...
can you buy the YO type and fit them on the SR2 recaros? or do you have to buy the RO type rails? Also i heard that the SR range recaros will fit on the bride rails. whether they are sr1-4. that true?
    3. 14
      Hi from Wagga
    6. 2
    7. 2
    8. 2
      Engine oil dipstick reading
    10. 1
      Landcruiser 13B Engine Swap
