Thermostat Location in 1996 Tarago
Penno
Can anybody tell me where I can find the 'Thermostat' in my 1996 Tarago?
By following the top hose, it appears as though it will be under the driver's seat...
Do I need to take the driver's seat and floor pan out to access it, or do I just remove the plastic guard underneath the van and access it that way?
Cheers.
Edited by Penno
Found it... Near the oil filter and accessible from underneath the car...
Easy to change...
But still have a problem so water pump next.....
There is a strange electrical noise coming from somewhere when it gets a bit hot...
Easy to change...
[/quot
how did you go with your Tarago , was it water pump ?
  • 3 months later...
I don't know if it is the whole problem... Like any problem, fix one and a new one arises...
It appears to be running OK now but the most recent problem is a HUGE shudder/vibration whilst accelerating...
Time for a new car I reckon...
hi matey ,im new to this club,i have same model like yours ,the vibration might cause by the rear driveshaft bearing ,my tarago was change couple years ago ,if its still original you need total replacement, aftermarket is as good,mine mileage 311,000 still runs good good luck
      Wheel size
    2. 0
      1zz-fe engine rebuild
    3. 14
      Rough cost of replacement bumper?
    4. 0
      2007 Corolla Sedan rear seatbelt question
      Hi from Wagga
    6. 2
      Amplifier 88650-60D60 no longer made
    7. 2
    8. 2
      Engine oil dipstick reading
    10. 1
      Landcruiser 13B Engine Swap
