Tailights CONT.
task
sorry boys i know i posted tailights one before..but it got pushed back too far.so don't think anyone would bother looking at it..
FOR DAN: sup my man...u know ur tailights...are they the stock ones that came with ur stivo? or did u buy them as aftermarket..cos i got aftermarket ones..instead of 3 lights..mine has 4....2 brakelights...yah..just wanna know thanks...
and also...anyone know how to wire the extra light up?
FOR EVERYONE ELSE: do you guys know where to get cheap foggies? cos i know if i got the genuine toyota ones..it'll cost ALOT.
Not sure about the facelift model, but www.ozeparts.com.au sell a driving light kit for the pre-facelift. The kit includes most of the wiring and a switch that will fit in the dash to replace one of the blanks. They are not 100% designed for the Aussie market, but the bit that's missing is easily sorted by the sparky.
They cost $320 or 10% less if you register as a member. One Toyota dealer quoted me $1000 to fit a factory set, and that was with a crappy toggle switch, $1300 if I wanted the indicator stalk from the Levin/Ultima/Sportivo models.
thanks mate...whoa 1k ? for foggies...no way...
ignition-x in broadway sells for around 500 i think but of course you
gotta install it yourself..
but iono...
1-1.3k...thats a bit too much...
$320 sounds good
thanks again
      Drive shafts
    3. 10
      front brake calipers
      Drive shafts
    7. 315
    8. 10
      Dashlight dimmer
