Engine block coolant drain on 2000 Corolla 7A-FE
Towbars
5
ASV50 Camry Head Unit Options
14
Hi from Wagga
Hi folks, I'm in Wagga, have what I thought was a nice, cheap and reliable 2007 Corolla, and am joining in the hope of picking the collective brain to troubleshoot and avoid tossing my computer and the relevant car parts out of the nearest window. I'll play nice and restrict the swearing to off line areas :D See you on the threads! Cheers Matt
