sluggish starting
SCOOTA44
I have had trouble with starting, it initially starts like its on 3 cylinders for about 10 seconds then runs fine. occasionly it does it at operating temp as well. I have recently replaced the plugs and its been the same from changing over the airbox to the SRI???? any clues??
VVTi controller on one bank not being at the correct alignment? Are you out of warranty?
Thats quite interesting,it makes a horrible rattling racket when it first starts up, maybe its one of those. I know the mech removed the rear left one when changing plugs. I did notice it had a bit of sludge in it. Maybe take them all out and clean them.
That would be a quick check, but I was talking about an internal part; the first or fourth items in the parts list here.
Thanks for that, will get it checked out next service, expensive parts to replace, dont want to bust any.
