Climate Control Cable Help
As parts like that typically live inside devices, getting them can be a bit tricky. You typically need to contact the manufacturer of the device. Does Denso build those units? If so, you can try your luck and see if they might be able to help, but I wouldn't imagine it being easy.
Alternatively, those cables are known as 'Flixible Flat Cables' and if you can count the conductors (it looks like 14 to me, but you need to confirm that) and can measure the spacing, then you may be able to source it externally. They may not be the exact length, but you can probably work around that.
Examples of such:
http://www.ebay.com/itm/PRINTER-AWM-20798-Flexible-Flat-Cable-14Pin-L10in-W15mm-/230294102567
Thanks for the replies guys!!
Yeah its 14 pins. Ill probably give toyota a buzz tomorrow and see if they sell it cos i rather get it straight away than wait for it on ebay.
Hopefully they have it.
Cheers again guys!!
Ps @eviltwin. Are u looking at selling your spare by any chance?
Not saying not to ask, but don't get your hopes up. It's like rocking up to your local Telstra dealer and saying you need a replacement screen for your phone. It's not something they deal with.
    6. 21
    7. 21
    8. 21
