member's aurion for sale?
Kua
I am new here, and thinking of getting an aurion, Saw this in carsales, and seen pictures of other aurions in this forum, so thought this owner from this forum?
http://www.carsales.com.au/all-cars/private/details.aspx?R=11580176&__Qpb=1&vertical=car&Cr=12&eapi=2&__N=1216 1282 4294962861 4294889509 903 4294889508&distance=25&silo=stock&seot=1&__Ns=pCar_PriceSort_Decimal|0||pCar_RankSort_Int32|1||pCar_Make_String|0||pCar_Model_String|0&Range=Price:Min,Max~1&__Nne=20&sort=default&trecs=26&__sid=132C0629F4D6
How much should I haggle this car for?
It is a neat car, but without seeing it in person any haggling advice you get is likely to be inaccurate and put you in the wrong frame of mind.
Haggling is a skill that needs to be learnt by the individual through experience.
As a start, take a look at www.redbook.com.au to get a idea of what these cars are valued at, as well as viewing the general going rate for these vehicles. Do the research yourself. Once armed with that knowledge form your own opinion on what you believe the vehicle is worth and negotiate from there. Speaking with the seller in person is likely to glean far better results than an email exchange, further it will let you inspect the car in person.
Don't be afraid to walk away from the car if the seller won't negotiate in good faith.
Hope this helps, but for basic stuff like this it is best to do your own research in future and consult family/friends before creating forum topics. Try to keep our forums clean :toast:
      Centre Bearing Replacement
    3. 6
      maps in 2017 Camry Altise
    6. 5
    7. 4
      Front Cameras
    9. 51
    10. 51
