my power window assembly has broken and needs replacing. The wires have frayed and while the motor works, doesn't want to play ball - needs replacing.
Where can I get one of these http://www.ineedarad.com/toranewpasif.html from without breaking the bank?
The one in the link is from the US and cheap but they want around the same to ship it.
Also, Ive seen a lot of newer version "X" configuration power windows for sale for newer Ravs' - would one of these fit the older version pre 2001?
Hi Matt,
There are a various different types. So you will have to be a little bit more specific…
  • 2 door for 4 door?
  • 3 pin or 4 pin plugs?
  • Front or rear door?
  • R/H or L/H?
There are many different wreckers in your area that may have your type of window reg available. Buy we will never know how long a used one will last...
If you do want to purchase from the US and they don’t send to Australia, try HopShopGo . They are part of PayPal and you can sign up for a US address then redirect the part(s) to Aus. Make sure it is compatible though.
To answer your question, no the newer model Rav 4 window reg will not fit in your 1999.
Hope this helps :D
    2. 5
    3. 0
      Tow bar
    4. 3
    6. 3
    7. 3
    8. 3
    9. 1
      Snapping wheel and axle studs
    10. 0
