new clutch cost
andersonsilva
When I last checked a new OEM replacement clutch from Exedy was around the $250 mark. Installation + labour was around the $600 area.
The job is a ***** to do and labour is a pain. I had mine changed at a Brake/Clutch mob but was letdown by some poor workmanship.
  • 2 years later...
I am also looking at replacing a clutch for a 2001 Camry v6 (Engine 1MZ-FE, Model MCV20). What was the cost in the end and did you use genuine parts?
This thread is almost 3 years old, please try to avoid bringing back threads this old. The member who posted this has not been active since 05 Apr 2012, so you will likely not get an answer. It is best to create a new thread. I don't think there is much point in leaving this open.
      1kzte throttle body
      Aftermarket parking sensor
    4. 4
      Head Unit with Apple CarPlay
    5. 8
    9. 1
      1kzte throttle body
    10. 3
