Power wire/pedal
Tvrdi
Sry for my bad english but I hav a problem....I experienced crunching/ (felt under my feat, i couldnt hear anything) just like my power pedal is sinking for few mm....is the problem in power wire/cable? The feeling is not intense and it comes and goes, (it comes only when the power pedal is slightly pushed...)
I hav Corolla 1.4 vvti (5/2004.)
Edited by Tvrdi
1.4???
When you say power pedal, I am assuming you mean the accelerator??
Have you had a look under the pedal....????
Edited by Azza
1.4???
yes, the accelerator :D under the pedal?...nope..you mean under the pedal in the car not outside (under the car)?
both
Yeah, that or his throttle cable is loose and some junk got under the pedel hinge assembly
maybe...anyway i did some oiling on the right spot (followed an advice) and its much better now....although I have another prob....
my gearbox is rather loud and somehow shifting from the 1st to the 2nd gear isnt smooth and without stumbling....local mechanics from Toyota said that for them gearbox is fine...yea right...
I took an advice from a friend and purchased MOS2 spray to lubricate bearings (and other parts of the "gearbox system") but i dont know where exactly I must spread with that spray....can you describe to me?
Edited by Tvrdi
It could be a clutch issue. Some of us Stivo drivers here had that probably and it turned out that the clutch wasn't disengaging properly.
