2008 camry Power seat fuse
Sirja
Hi Again guys !
I am having great trouble trying to find the Power Seat fuse, its not in standard fuse box.
I do wonder if its in one of the fusible link assemblies, but I cant find any info about this.
any help will be greatly appreciated
Thanks again!
sirja4562 ; }
refer to this
LOLOLOLOLOL. Look at it from the floor up.
Edit: You took the long and hard way to get there.
Turns out that I can be fuqed searching. Hahaha
http://au.toyotaowne...showtopic=18725
Search was for 'lighter fuse'.
Shock horror, Daryl was the one that replied with all the info. Haha
Lighter fuse
I have blown the lighter fuse (no voltage on the outlet anymore after testing with a multimeter). I have checked the fuse box under the hood but can't seem to relate a fuse to the lighter, they all seem to be NOT blown. Any idea what it's called, or which on it is ??
THanks
Look at the fuse box inside the car. It is located behind the glovebox and is accessed from the passenger side footwell. All can be accessed with no tools at all. Let the pictures do the talking (sorry bout the dust, and ignore my footwell lighting):
To remove that the panel in the second photo, you can see 4 clips at the front (bottom of photo). Use a little imagination there. If your finger is small enough, you press the clip in through the hole underneath. You should be able to figure it out when you get to it. The fuse/s you are interested in are labelled 'PWR OUTLET' and 'CIG'.
This "SORT OF" helps me, but how do I get to the "POWER SEATS" fuse its behind all those fuses, Toyota in Goulburn reckon itll cost about $50 to replace it. I'd rather do it myself.
Any ideas ?\
Any ideas ?\
Look at the fuse lid,and find the fuse
For the seats, I'm not at home ATM,so I can't see or look at mine.try the manual to see if they list it.
$50 for a fuse ? Crazy to pay that price
      help with clutch
    2. 3
      newbie from Queensland
      High mileage camry
      1981 Hiace ignition upgrade
      Aftermarket Air Intake
      Heater problems
      Entertainment Unit Upgrade
