repair power steering box shaft
Manxman
I hear no-one does these exchange. Common prb is the water trapped between the 2 seals on the bottom corrodes the shaft.
My first guess is to try a Speedi-Sleeve. They're cheap and easy to install, and I'm sure they could be often fitted before it got more expensive than a full rebuild--weld/bronze/grind and chrome, or new part.
      ‘97 Petrol 6 cyl ‘80 Series knocking/rattle below
      1989 Hilux Low Voltage
      Ae92 genuine low ks 70800
      Code P004B
    9. 1
