Oil filter moisture
I have a question in regards to storing my oil filters in the shed. Today when I went out to the shed to find a filter for my Corolla, I discovered that all my oil filters were soggy and some had rusted. I had these oil filters on the floor in a plastic bag and I assume that the moisture from the ground heas seeped through the cement slab. Now what I want to ask is... can I still use these filters?
Apply this level of sense to it. If that were a water filter for your tap water, would you still use it in the condition you found them in?
Why are you storing oil filters anyway? Unless you did a bulk order or something you should only buy a filter right before you are about to install it
    2. 4
      RATTLING CAMRY 2013
      Canning Prado or 200
      2002 Door Handle Issue
      What to say!
    10. 1
      Just joined
