1zz oil pan instead of moroso?
hi guys has anyone ever put a 1zz sump on a 2zz before? i have recently found out the 1zz has a baffled oil pan and i can get one cheap, is it worth it ? what you guys think ?
you can see from the pictures the diffrence between the 1zz and 2zz oil pans
Edited by scott5
I've got a 2zz sump, if anyone wants for $, also have other spare parts ie a whole motor minus 1 piston and rod..
Just saying
Also, why change the sump? Mine seems to hold oil fine haha
although the 1zz sump is baffled the moroso is both baffled and gated. Added to this is the fact that the moroso will also allow you to hold almost 6L of oil.
Here's what a moroso looks like .... only issue i had was the dip stick wouldnt go in properly so we had to take a little cut out of the baffle.
as is always the case .... my moto is do it once do it right
Sorry for the late reply ..thanks for the pictures zoom. I might just got with the moroso oil pan Your moto sounds right lol. Thanks for the help guys
Edited by scott5
Edited by scott5
      Upgrade from 2012 to 2023
    5. 3
      Towbars
    6. 5
      ASV50 Camry Head Unit Options
    8. 2
